| Posted by Anthony on January 13, 2003 at 15:23:52: | |
| In response to Re: Salt free water softeners | |
I believe theirs has a timed backwash that is supposed to happen once per day. They claim this will backwash the trapped impurities down the drain. They also claim that the calcium is somehow changed without using chemicals so that it can be easily wiped away (on your sink, etc.). I guess I just don't know enought about the whole process to know what to do. We don't even have our well drilled yet so I don't know how our water will test. Should I just face the fact that I'll have to buy salt for the rest of my life and have one more appliance to maintain? : Unless I missed something, they call theirs a filter and water treatment unit, not a water softener. As such it would be an adjunct to a water softener, but not a replacement, regardless of what they say. Removing impurities is not the same as altering its composition to remove the calcium component. Using "scare tactics" to discredit softeners and boost their units tends to make their claims somewhat suspect. In addition, all the material that they remove has to go somewhere. If it remains in the unit, then the unit either has to be serviced at some time, or the stuff will increase to the point where the unit has to let it pass through and sometimes also carry some of the accumulated "junk" with it making the water worse than when it started. :
