| Posted by hj on January 13, 2003 at 07:56:21: | |
| In response to Re: Garage drainage | |
It would not be harmful to the garage floor, but it appears you already have a poorly installed floor, if it settled at all, much less that much. The only long term, possible, problem is an environmental one similar to connecting it to the sewer. And grease and oil spilled on the floor that drains into those holes will contaminate the ground : I recently had my single gagrage doubled and a new garage slab was put in. I had asked for a drain to be inset into the floor to handle melted snow, etc but learned it was against the code because of possible oil drips, etc. The floor was sloped towards the door, (stress cuts were also made on the floor) but it has since settled and defeated the slope. Water now collects right under the front wheels of the car as the snow melts off, and moves laterally, making large puddles that must be walked through to go into the house, and soaking everything along the sides of the garage. I end up having to squeegee out the garage almost daily during winter weather. : Many thanks,
| There are none. |
