Re: Trowelled cement shower
Posted by Sparks98 on January 11, 2003 at 03:03:29:
In response to Re: Trowelled cement shower
: I would like some advise as to what should go underneath : my cement if I want to make it leak-proof : Should I lay a solid sheet of lead and have the : drain come through the middle? : How do you attach the lead to the floor without : puting holes in it?: Any advise would be great I have just installed such a shower, the cement base is referred to as a 'wetbed'. The previous advice by Sean sounds similar to what I did, but if you want a good step-by-step detailed manual with pictures to boot, then visit the John Bridge Forum (www.johnbridge.com). Also, make sure to use a good butyle rubber caulk between the drain and the rubber liner or it WILL leak. Test it by filling with water overnight before laying down the wetbed.
Replies to this post
There are none. |
