| Posted by hj on January 10, 2003 at 08:03:36: | |
| In response to Re: New Shower Stall | |
You have to decide whether you want to go to the expense and labor of acrylic. The plumber will charge whatever is necessary to install the parts. That depends on what has to be done and the time and materials necessary to do it. : Need to put in a new shower stall - is it worth going acrylic or is fiberglass good enough. I am installing the unit - what should a plumber charge for installing a new valve and refitting the drain? Thanks
| There are none. |
