| Posted by bobb on January 09, 2003 at 22:19:53: | |
I'm removing a neo angle shower. it's about 15 yr old. it's on a plywood subfloor. the pan was not secured to the floor other than with a bead of caulking. i pulled the drain strainer out to detach the drain, but can't figure out how. The pan is loose, but is being held down by the drain. any idea how to undo the drain connection? thanks, |
