| Posted by Marvin2 on January 09, 2003 at 22:13:35: | |
| In response to Re: Cold pipe is hot | |
: Nope, it checks out. Appreciate the suggestion. : Make sure that cold water supply is connected to the "cold" inlet and the hot water pipe comes from the "hot" outlet. If you cross the connections you could have the problem you describe.
| There are none. |
