Re: Constantly Clogging Toilet
Posted by Don on January 08, 2003 at 08:41:22:
In response to Re: Constantly Clogging Toilet
: : Have you tried changing your toilet paper? Sometimes the 'fluffier' stuff will cause clogs..... : : : : : : My house was built less than three years ago and from the start we have had problems with the toilet on the opposite side of the house constantly clogging. Our house is only 2200 square feet and we have two full baths. If you flush without holding the handle until the water disappears your bound to have a clog. Then very little paper the system will clog. It seems the strength of the flow is very weak. The toilet in the master bath is a little stronger but it can also clog if we're not careful. The water pressure at the faucet is very strong so I don't think this is the problem. Do I need new pressure toilets because this is getting really old. Thanks for any assistance. : : : Don We use the thin paper but still have this problem. Can anyone recommend a replacement toilet
Replies to this post
There are none. |
