After flushing my toilet, it fills up fine, but after about 2 hours, the water kicks back on for about 20 seconds to fill up the tank again. I put in one of the colored tabs after the flush to test for a leak. The water in the bowl turned the tab color, so there is a leak from the tank to the bowl after the flush. Now what???? There are no directions on the free tab from Home Depot an what to do if the water in the bowl turns color and indicates a leak. I have 3 toilets that I have replaced the float with the FluidMaster 400 and all 3 are having the same problem. Any help would be appreciated.
