Re: knocking hot water pipes
Posted by Tim on January 06, 2003 at 16:49:02:
In response to Re: knocking hot water pipes
I have had the same problem with my very old house. It is easily fixed. You have to put a 10 to 13 inch extension on your hot water pipe. I has to go on the highest point in the house...usually the shower on the second floor [if that applies]. If there is a T fitting on the hot water feed to the shower head, it will make the job a lot easier... good luck
Replies to this post
There are none. |
