| Posted by Mark on January 05, 2003 at 22:48:59: | |
I have a RH skew pan that is sitting 195mm (centre of the outlet pipe) from the back wall. I want to replace the whole unit. I have been told that I can use a P-trap with a turn trunk as long as it will join to the existing outlet. I want to use an ideal standard "reflections" low-level My existing plumbing is 80mm the suit is 100mm. I figure that 265-80 = 185 which is 10mm closer to the wall that the existing pan. The connector that adapts 100mm to 80mm will be a rubber boot. Will this boot take up the 10-20mm difference or is some other solution required ? |
| There are none. |
