| Posted by MattC on January 05, 2003 at 10:24:46: | |
| In response to Re: Pop-up sink drain with copper sink | |
HJ, Would I have to custom make the spacers (if so, how would I do that), or are there spacers available some where? : You will have a problem finding any kind of drain that will fit the sink, since I assume it is just a single thickness of metal. You may have to insert a spacer to provide the thickness a typical drain needs.
| There are none. |
