| Posted by MattC on January 05, 2003 at 10:19:47: | |
| In response to Re: Baseboard heater pipe repair...need help. | |
Well, I thought I removed all of the water from the system. But, I guess it's possible that I didn't. I will try it again and make sure there is not water there. It's interesting that you say that, because after I realized that the coupler wasn't going to come off, I thought that I had probably made the leak worse by my monkeying around with it. I tired to temporarily melt more solder around the joint to hopefully seal the leak a little better before I, or my plumber, got another wack at it. I heated the pipe up again and the solder wasn't melting when I touched it to the pipe. How long do you guys normally hold a flame to a butt joint before it loosens for you? How much flame do you give it? |
| There are none. |
