| Posted by hj on January 04, 2003 at 18:57:00: | |
| In response to Re: Pop-up sink drain with copper sink | |
You will have a problem finding any kind of drain that will fit the sink, since I assume it is just a single thickness of metal. You may have to insert a spacer to provide the thickness a typical drain needs. : I recently purchased a copper sink. Typical sinks can use a pop-up drain that has the cutout for the overflow above the flange. But this sink does not have an overflow. Can anyone tell me where I can find a pop-up drain without the overflow cutouts?
