| Posted by Rob Kaplan on January 03, 2003 at 13:25:51: | |
Just remodeled our daylight basement, and the forced-air isn't enough. When the furnace is on, the rooms come to temperature, but then the heat rises up the stairs and the room temp drops up to ten degrees. Rooms are adjacent to hot-water heater: what about a hydronic line to some wall-panel radiators? Any problem with systems that run off hot water heaters? Can you recommend anyone in the Eastside Seattle area? Thanks. |
