| Posted by hj on December 30, 2002 at 08:09:51: | |
| In response to Re: stuck drainpipe | |
Sometimes with great difficulty. That connection was used to make it hard for a do-it-yourself person to work on the drain. Plumbers called it "job security". You have to use a hacksaw to cut a small slot out of the brass piece and then use a chisel to remove the rest of it. : Hi, : Thank you!
| There are none. |
