| Posted by hj on December 30, 2002 at 08:07:23: | |
| In response to Re: Whinning noise after turning off water. | |
How would the air get into the pipes? It is usually a water softener or pressure reducing valve making the noise. If you have either, or both, check them while the pipes are making the whining sound. : I have a whinning noise after running water or flushing a toilet. Is there air in the pipes? If so, what can I do?
| There are none. |
