Re: Please help! Noisy bathtub drain
Posted by ClogCleaner on December 28, 2002 at 11:02:49:
In response to Re: Please help! Noisy bathtub drain
this may help...but need more info.....what did the drain cleaner/plumber pull off his cable after cabling it. did he camera your line(it probally needs it) what type of chemical/solvent did you pour in the line..was it Draino(if so, that may be your problem),Drain opening acid(Thrift,Sizzle,Break-Thru,etc),how long has this been going on(since you bought the house?yesterday?2 weeks ago?).....check the vent stack(does it have one?)....hope this helps a little. ClogCleaner
