Re: RE: Sudden Drain Clogg ***
Posted by Casman on December 27, 2002 at 14:34:24:
In response to Re: RE: Sudden Drain Clogg ***
Well, if we rent a snake, should we run it from the roof top vent or the wall opening or should we cut open the wall and look for the cleanout? There isn't one outside???and I'm not sure there is one in the wall either, it's a sink drain! What's the difference between running a snake through the wall vs. the cleanout, if there is one? If the first post wasn't clear the double sink pipes have been removed and all we are looking at is the drain hole into the wall...Help...
