| Posted by Neil on December 26, 2002 at 03:43:08: | |
| In response to Re: Particles blocking water flow | |
Terry, Are the particles blue or can they be white? If the waterheater (gas) is 6 years old, do you recommend fixing the old and replacing the whole unit? How is the dip tube replaced and how much should the repair cost if professionally done? I recently had to raise the temp on my gas water heater to C (A,B,C and Very Hot) and we still have to keep raising the hot water levels during showers. I took the shower head off because of the noticable drop in water pressure and found tiny white particles and one long sliver of of white plastic. I have flushed the hot water heater and got a bunch of minerals which are white and green. Coincedentally, all of this began shortly after we had a central humidifier installed. They tapped the hot water line 8" above the hot water heater. Since cleaning out these particles from the shower heads, water pressure is once again normal. I shut off the water supply to the humidifer with no change, so now I am think the hot water heater has issues. Thoughts? Thanks, Neil : Rakesh, : : Hi, : : thanks,
