| Posted by hj on December 23, 2002 at 08:49:51: | |
| In response to Re: Brownish Hot Water | |
Something in the hot water system is rusting. It could be the tank, the heater element mounting, a pipe, or a fitting at or near the tank. : We have a water filtration system (Just for information) Lately we've notised that when we fil our tub, the woter is not as clear and clean looking as it use to be. It's not tinted a bit brownish. Do you think this could have something to to with the filtration system (I just checked to be sure there was enough salt. Or do you feel it may be the hot water heater. When we fill the tub with cold water it is not brownish, although it's not a clean looking as it use to be. : Thanks
| There are none. |
