| Posted by Sara Backer on December 19, 2002 at 14:16:02: | |
| In response to Re: vibrating pipes | |
: In the past cople of weeks after the cold water system has been activated either by a shower or toilot flush or even running the pipes will start to vibrate. sometimes this kasts for up to an hour. Can anyone offer some assistance: : : For the last couple of weeks when the fauset is turned on low(any fauset) hot or cold, the pipes vibrate. If more water pressure is added, the vibrating stops? : : If it's the entire house, I would look for a pressure reducing valve that needs repair or replacement. What if it just happens in one room (master bath)? |
| There are none. |
