| Posted by hj on December 17, 2002 at 22:41:35: | |
| In response to Re: How do I dry fit PCV pipe? | |
If you bevel the end to remove the ridge caused by cutting the pipe, it should go almost all the way into the fitting. : Hi, : Is there a recommended way to get the pipe to bottom out in the fitting but still be easily removed and cleaned before gluing? I was thinking liquid soap but I wasn't sure if that would affect the glue. Basically, it looks like I still have a 1/4" more I could push it in to the elbows, etc but if I force it, I will never get it apart. : On a similar note, I am assuming that I need to push the pipe into the fitting until it bottoms out for the best seal. Is that a correct assumption? : Thanks for your help!!
| There are none. |
