Re: Vibrating pipes
Posted by Terry Conquest on December 16, 2002 at 18:36:59:
In response to Re: Vibrating pipes
Sounds like you have an airlock or a valve seal that is not seating correctly, airlocks can be cured by forcing water in the oposite drection (From the cold tap directly to the hot tap for examle) though be careful that you don't flood the loft!
If it is a valve seal that is not seating, you need to get either a new valve, a new seal of a valve seating tool.
Replies to this post
