Re: Replace Corroded Toilet Tank Bolt?
Posted by Andrea A. on December 16, 2002 at 17:58:58:
In response to Re: Replace Corroded Toilet Tank Bolt?
Both bolts are very corroded. They don't have screw slots on top, and the fastening nuts on the outside are also badly rusted. So far, I haven't been able to remove them. Any suggestions?
: Get new bolts and center gasket and remove the tank from the bowl and replace all of them.
: : I have an older Briggs toilet that is apparently leaking from a corroded tank bolt (slow rusty drip coming from location of rusted bolt). Can I easily replace this bolt myself without having to remove the tank and replace the ring? Also, are the tank bolts standard sized?
: : Thanks,
: : Andrea
Replies to this post
There are none.
