Toilet PVC Drain Layout Question
Posted by Rob on December 09, 2002 at 06:21:03:
Terry,
I have two layouts I'm considering for draining a
toilet, shower and tub. The toilet is at the end of the run and I want to connect a 2" shower and a 2" tub drain to the 3". Should I connect the shower and tub drains below the toilet or in-line with the toilet, does it matter? The distance from the toilet to the 2" vent connection is 4 feet and the tub has its on vent line. Should I provide a seperate vent for the toilet
or wet vent it with the shower drain?
I've layed out the 2 approaches below in a diagram.
Thanks for the advice
Rob
Approach I
^^ out to vent
2" vent ||
/ =================|| 2" vent
--------- <--- 4'---->|| 2"
3" 0|====================O (shower)
||2"
xx (Tub & Shower lines connect)
Approach II
^^ out to vent
2" Drain || 2" vent
--------- ~~<-- 4'-->|| \ \
3" 0|============== O (shower)
|| Toilet Vent Line
||2"
xx (Tub & Shower drain lines connect)
Replies to this post
There are none.
