Re: Hole repair in Copper Pipe
Posted by Rick on December 01, 2002 at 21:15:48:
In response to Re: Hole repair in Copper Pipe
The guys a friend of mine and will probably be the one helping me with the ceiling. He's actually came through for me in the past a couple of times so I don't want to hurt the relationship. I hope when we get to working on the ceiling, clear out the rest of the material in the way, that he will get it done properly. I'll remind him:) Thanks again,
Rick
: I would assume that the contractor that damaged the line should be the one having it repaired, and repaired properly.
: : Thanks for the reply, we are going to redo the ceiling within a couple of years, so hoping it lasts that long, I will get it repaired properly once I clean out around it. Thanks again for your help,
: : Rick
: : : That is a good temporary repair, but I would not trust it for the long term. We ahve many ways to repair pipes in tight places, and a good plumber might have a bit of a problem but could do it.
: : : : Hi There;
: : : : My contractor drilled a hole to run my satellite cable in my house and nicked my cold water line (after the pressure pump) for the house. The nick is about a 1/4" to 5/16" in size, and in a very tight spot. He brought in a plumber who said it was too tight to get to with solder, a proper coupling and a torch, so he put a 1/8" thick piece of rubber over the hole and sealed it with three small hose clamps, which he said would last just fine. Is this possible? I am worried about getting the ceiling reinstalled and the joint leaking in a few years.
: : : : Thanks for your help,
: : : : Rick
Replies to this post
There are none.
