| Posted by Terry Love on November 30, 2002 at 14:40:41: | |
| In response to Re: Water level in Caroma Caravelle | |
![]() The Caroma has a low water level in the bowl. There is no adjustment for that. It's determined by the top of the trap. You can't get the water to set higher than the top bend. Once water has gone over the dam, it's gone. Terry : I had installed the Caroma toilet. It seems to work well but the I am hoping there is an adjustment that can be made to the water level in the bowl when the toilet is not in use. As present the default level is too low and so the bowl stains more easily because the water is not high enough in the bowl. I have looked at the installation instructions but they are scimpy.
| There are none. |
