| Posted by hj on November 30, 2002 at 07:57:36: | |
| In response to Re: How long to hold down the button for a Caroma flush? | |
IF it is a "power flush" model, then that will be the normal operation, since the initial flush is powered by the air bubble and then the incoming water will continue to flow if you hold the button. If it only flushes while you hold the button, then tank is water logged and has to have its air bubble restored. : Unlike traditional toilets which continue the flush after one has released the depressed handle my Caravelle doesnt have that feel. That is, one can continue the flush as long as I hold down the button. Is that the intent?
| There are none. |
