| Posted by billy smith on November 25, 2002 at 19:48:39: | |
| In response to Re: toilet has air coming out of it | |
thank you for your help : The sewer is plugged. As the water enters the pipe, the air coming into the toilet could either be what is trapped under its trap or you could have a mechanical vent fitting the prevents the air from escaping normally. : : the toilet has air coming otu of it when the other drains are being used and it also doesent flush corectly what would be the most likely problem
| There are none. |
