Re: Toilet Flange Too High
Posted by Gary Swart on November 25, 2002 at 16:24:42:
In response to Re: Toilet Flange Too High
I think you'll have to go under the floor and cut the pipe back so new fitting can be installed. Problem is, there must be a 1/4" per foot slope in the drain, and since the closet bend is flush with the floor, this could mean the drain pipe is setting so high the new fitting will not allow the slope. If that's the case, you will have to find a way to lower the drain pipe to get the slope.
