The bolts that connnect the tank to the bowl drip
Posted by Terry Love on November 23, 2002 at 16:51:36:
In response to The bolts that connnect the tank to the bowl drip
 Instructions for any toilet, Check for smoothness where the bolts with rubber washers drop down into the mouting holes of the tank. If rough, the surface can be sanded smooth. Tighten fairly snug. Terry Love : I installed a toto promenade tonight (2-piece). I am getting a consistent leak between the tank and the bowl. It appears to be at the bolts that mount the tank to the toilet. Exactly how tight should those be? The flush valve seems to be tight, and as far as I can tell, the flush valve gasket is not the source of the leak (the leak will occur with water standing in the bowl). Any tips would be greatly appreciated.
: Thanks...
Replies to this post
There are none. |
