Re: Toto install problems...help!
Posted by Jim on November 23, 2002 at 01:02:06:
In response to Re: Toto install problems...help!
Correction...that should say "water standing in the tank"...not "in the bowl"
Thanks....
: I installed a toto promenade tonight (2-piece). I am getting a consistent leak between the tank and the bowl. It appears to be at the bolts that mount the tank to the toilet. Exactly how tight should those be? The flush valve seems to be tight, and as far as I can tell, the flush valve gasket is not the source of the leak (the leak will occur with water standing in the bowl). Any tips would be greatly appreciated.
: Thanks...
Replies to this post
There are none.
