| Posted by hj on November 22, 2002 at 07:46:18: | |
| In response to Re: the water shut off valve under bathroom sink | |
Fixing a faucet is much more difficult than turning off the water to the faucet. I suspect you should call a plumber so you do not damage the faucet to the extent that you will have to replace it. : HELP. I TRY TO FIX A LEAKY FAUCET. I SEE A TURN SWITCH UNDER SINK. IS THAT THE SHUT OFF VALVE? NEED HELP TURNING WATER OFF SO CAN FIX LEAKY FAUCET. : THANK YOU.
| There are none. |
