| Posted by Brian on November 20, 2002 at 03:39:06: | |
| In response to Re: Replacing a Briggs wall mount toilet | |
Greg, Is this a two piece Briggs wall hung toilet or a one piece unit? If it is a one piece unit (either Briggs #6000 or Case 3000) then you will have to modify the existing carrier by removing the upper hanger bar and put in the extentions for the upper two bolts. If it is a two piece toilet, then any new wall hung should work. AS makes one called the Glenwall and Eljer makes one called the Walford.Both of these are pressure assisted. For more specific details of this work, you may wnat to ask real plumbers like HJ or Terry. They can give you a better explanation than I can. Hope this helps. Brian |
