Toilets and tubs not draining
Posted by Beth on November 19, 2002 at 13:41:55:
Tubs and toilets backing up Author: Beth I suspect that my sewage tank is backing up. I began seeing a problem when my kitchen sink stopped draining two days ago. Thinking that some grease might have clogged it, I poured in dishwashing liquid and hot water to break it up. This worked. However, since then I have had both of my toilets cease to flush (they overflow when I try to flush them) and my two tubs don't want to drain (one even filled up slightly with what appeared to be --gag--the contents of the toilet from earlier in the day). Drain-o helped the tubs start draining again (very slowly), but the toilets still do not want to flush. So, I need advice. It is always a huge chore to get a plumber to my house, and it may take a few days. What are some things I could do in the meantime to help ease this problem, or at least not make it worse?
Replies to this post
There are none. |
