Re: What is advisable water pressure at water heater
Posted by Terry Love on November 19, 2002 at 11:46:06:
In response to Re: What is advisable water pressure at water heater
 : Thanks guys...I thought the new tank could handle at least a little higher pressure. Any thoughts why the installer was hooked on 60 as the max allowable ? : After I buy a gauge and hook it up the same, which way do I turn the screw sticking down out of the pressure valve ? Screw it in or unscrew it? If I was a betting man I'd say screw it in, but... You lose! "out" will raise the pressure. I don't know why the installer like 60 so much. 60 should have worked though. Are you sure that all of the shutoff valves are in the full open position? I like to open them, and then turn the handle back in, just a bit. That way the next person that grabs the handle can determine better which way the handle should be turned.
