Posted by Sue on November 19, 2002 at 01:15:17:
In Reply to: Re: Lack of hot water in shower posted by tjwright on November 18, 2002 at 19:28:29:
: I haven't contacted the plumber. This shower repair is a short-term solution until we are ready to remodel. I chose the most inexpensive faucet. It has one handle that is supposed to be the hottest when you crank it all the way counterclockwise. My husband thinks there might be a set-screw on the handle shaft that has been mis-set. Since it is tiled in, I may have to live with it. I will take the handle apart when my Dad is here to help put it back together.
: This problem does nnot stem from your hotwater heater or the lack of circulation. If that was the problem, your sink furthest from the tank would be in trouble too.
I have the same type of shower faucet handle. The plumber said he adjusted something inside it to try to allow more hot water in, but nothing helped. Sounds like we must have the same type of cheap faucet! Thanks! Sue
