Delta "Monitor" Shower (low pressure problem)
Posted by Debbie S. on November 18, 2002 at 16:20:04:
I have a Delta single handle (shower only) faucet/valve that will not produce normal flow or pressure. It is less than 2 years old (new home construction) and has never produced normal (good) flow. Everything else on this water line (whirlpool tub, sinks, toilet)has great flow. I understand this Delta "Monitor" system is a pressure-balancing type of valve designed to prevent scalding.
Is there any way to adjust this valve for more flow? By the way, I changed shower heads already (and tried it without a shower head alltogether) increase in flow.
Replies to this post
There are none.
