| Posted by Gary on November 17, 2002 at 19:56:47: | |
| In response to Re: Pedistal sink install leak | |
I usually pre-set the trap outlet section to the proper length coming out from the wall,,then set the p-trap assembly on the sink,,set the sink on the pedestal and you should have access to the trap outlet nut for tightened,,then secure the sink to the wall.
: I finally loose fitted the pedistal and sink with the tailpiece tight and everything tight on the other end and slip them together (pedistal spun around on the bolt) and tighten. If I test it now it runs dry. BUT once I spin the pedistal back around and tighten down the hanger bolts and pin the tailpipe leaks (POURING leak) at the top of the tailpipe. : I then can't get in there with any tools to try & retighten. HELP! This is making me crazy. I've taken it apart and put it back together several times, always with the same results. What am I missing? : thanks!
| There are none. |
