| Posted by Gary Swart on November 15, 2002 at 15:12:13: | |
| In response to Re: soldering copper pipe/water shut off | |
Karen, you only have to have the pipe you are soldering dry. Sounds like you're OK, just flux the fitting where the leak is and heat it. If it's dry you're fixed. If it isn't dry, the solder won't flow. |
| There are none. |
