Re: Toilet runs intermittently when not in use
Posted by Gary Swart on November 14, 2002 at 13:29:11:
In response to Re: Toilet runs intermittently when not in use
The problem is the float valve in the tank. Most likely the flapper at the bottom is not sealing tightly and that is allowing the water level in the tank to slowly drop and as when the float is below the level that it shuts off, the water again runs. It's a fairly easy and inexpensive fix, just get a new Fluidmaster valve and float assembly.
Replies to this post
There are none. |
