| Posted by Melanie Loper on November 14, 2002 at 01:23:32: | |
| In response to Re: QUEST PIPE, THE TRASH THEY USE IN TRAILERS | |
: IF the unit was constructed after Sept. 1991, and the leaks started before Sept. 2001, then call 1-800-356-3496 and submit a claim. If it was before that time, then you are past the time frame required to make a claim. : : I BOUGHT A MOBLE HOME IN 1994,ITS A SKYLINE HOME W/QUEST [GRAY] WATER PIPE. I ONLY HAD MY HOME FOR 7 MONTHS AND BEGAN TO GET LEAKS.THE PROBLEM IS MORE IN THE FITTINGS, BUT I HAVE ALSO HAD LEAKS IN THE PIPE ITSELF.SOMEONE TOLD ME THERE IS A CLASS ACTION LAW SUIT
| There are none. |
