| Posted by Philip on November 13, 2002 at 21:08:08: | |
| In response to Re: How to insulate a full bath? | |
I had a similar question. This is the resulting thread: http://johnbridge.com/vbulletin/showthread.php?threadid=3698 I highly recommend this site for tile advice. Search on the key words "moisture barrier". If you need help, post a question. Alot of pros will respond and give advice and encouragement. The whole issue of moisture barriers seems to be a can of worms. You will get conflicting information. You would think by now there would be a uniform approach but that doesn't seem to be the case. What I have been able to gather is this: 1) If using green board (do not use for showers of tub surrounds), do not use a moisture barrier. Kraft paper on insulation is okay. 2) If CBU (cement baker underlayment), use a moisture barrier of 4 mil poly or 15 lb tar paper. By the way I am a DYIer. So you will need to do further research.
