| Posted by Gary Swart on November 12, 2002 at 15:11:52: | |
| In response to Re: Water Out Of Pipes So I Can Solder? | |
The bread trick usually works, I've used strips of towel and a long dowel to soak up water, and sometimes I had to cut pipe so I could drain it. Makes the finished job look pretty grim, but you just have to do what will work. |
| There are none. |
