Re: Shower drain fastening
Posted by hj on November 09, 2002 at 09:56:54:
In response to Re: Shower drain fastening
Usually, you install the drain pipe the proper distance above or below the floor depending on the shower fitting. The shower fitting then fastens to the stall with a locknut similar to a kitchen sink drain. Then the shower is installed over the pipe and a rubber gasket is inserted into the drain, (around the pipe), to seal the connection.
: I am currently building a bathroom in my basement. I have ordered a one piece fibreglas shower. Now I'm worried that I may not be able to get the drain in place with the ceiling height I have.
: How is the drain actually attached to the shower? Does it have to a threaded nut underneath similar to a sink drain? I was hopeful that I could set the shower over the exisitng drain pipe and then cement the drain to the and caulk the drain to the shower with silicone. Is this an option. I have searched the web for a installation diagram with no success. Any leads?
Replies to this post
There are none.
