Re: PVC to Cast Iron Transition
Posted by Terry Love on November 06, 2002 at 10:28:00:
In response to Re: PVC to Cast Iron Transition
: 3" PVC drain is replacing 3" copper, : which ran vertically into a cast iron, : in preparation for going below grade.: Original copper was soldered (or maybe : oakumed) into the iron. : Cast iron part is flanged at end, : so no-hub transition won't work. : Is there a rubber fitting that will : seal between the new PVC and the : existing iron? Tim, Fernco makes a rubber seal that replaces the lead and oakum seal. When you have removed the lead by drilling or sawing it out, a little prying works too. You can insert the rubber seat, taper the end of the plastic, and lube it with liquid soap. It should push in, intil it bottoms out. Terry Love
Replies to this post
There are none. |
