| Posted by hj on November 05, 2002 at 07:27:06: | |
| In response to Re: shower drain | |
No difference. : It is for a three piece plastic. I have access to the bottom. Any difference in performance? : : It depends on what you are doing. The glue on ones are typically used for ceramic tile bases, and the gasketed ones, since you normally cannot get to the underside to glue it in, are used for preformed bases. : : : do the shower drains that compress on 2 inch PVC typically work well or would I be better off with a glued connection? It seems the glue would be much better and safer, but not sure...
| There are none. |
