| Posted by Gene on November 04, 2002 at 15:39:22: | |
I have an older house with copper waste as well as supply. I'm remodeling a bathroom which had a tile floor set on a cement bed over the subfloor. I plan on replacing the tile floor over cement board and would like to remove the flange and reinstall it to the correct height after the tile job is complete. I've used MAPP gas and even propane/oxygen to heat the joint up. It won't budge. Any suggestions? Gene |
