Re: Odor from kitchen sink area
Posted by Tom on November 02, 2002 at 21:26:58:
In response to Re: Odor from kitchen sink area
In our kitchen sinks, there's a blackish biomass coating that grows around the inside of the plumbing and stinks real real bad. It requires you disassemble the plumbing between the sink and the drain trap and scrub each section of tubing (ours is PVC) with a green scrubby pad. Make sure you clean out as much as you can, for just a little bit will still stink. That's why cleaners only dumped inside won't work, it needs to be scrubbed out. Hope this helps.
Replies to this post
There are none. |
