| Posted by hj on November 02, 2002 at 08:37:24: | |
| In response to Re: 90 angle coming coming out of sump pump? | |
There is no reason that you cannot do it as long as the pipe is secured so it cannot come apart. : My sump pump sits down in a hole in the concrete in my basement. Currently, there is a pvc pipe coming straight up out of it. It goes about 8 feet straight up, then turns 90 degrees into the floor above. I want to turn it 90 degrees at the basement floor so it runs along the floor (about 30"), then goes up the wall. Any reason I shouldnt do that? I want to do this so I can then build a platform over it (with an access panel of course..) and be able to use that space.
| There are none. |
